23mm overflow?
View the thread, titled "23mm overflow?" which is posted in Central Heating Forum on UK Plumbers Forums.
Knappers
Put a boiler in this week and positioned it nicely to use the old condense thats run behind plasterboard but ended up snapping it if at the elbow, no probs I'll cut a neat hole and connect onto the pipe with an elbow.
WTF is 23mm overflow! I can't get anything on it, too tight for mechanical adapter.
I ordered a polypipe pushfit condense elbow thinking it would be rubberised (they're not).
I tried heating and 'swaging' normal 21.5mm.
I can get an adapter but to get it in I'll need to remove some mosaic tiles :-/
Any tricks with this one?
I'm back on Friday to replace the very ropey condense to sink arrangement- I nearly cried 🤣
Heat it up and swage the end as it’s slightly bigger shouldn’t be too hard
Can you get normal overflow down inside it and then stixall around the joint?
Might need to heat the existing pipe a bit.
Thanks. I can get a straight weld adapter, just need to take a couple of tiles out and open up the wall, I think that's the way its going.
Could use a rubber condense elbow off a baxi but don't like the idea as won't be accessible.
Thanks Scott, that's actually what I got.
Took out a couple of tiles to expose the pipe, cut it and then realised just below was another fitting so I couldn't get it on fully.
Sometimes it just doesn't go your way.
Its on and only time will tell if its on enough 😬
Reply to the thread, titled "23mm overflow?" which is posted in Central Heating Forum on Plumbers Forums.
Knappers,
Knappers,
