3/4" blanking caps
View the thread, titled "3/4" blanking caps" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Dannyparty92
Purchased some 3/4" blanking caps from tool station today and I didn't check them until I got home but they didn't come with any rubber washers inside. I need to blank off a wheelhead valve because the rads been removed for decoration and the valve still leaks. Will a fibre washer in the inside of the blanking nut do I will I need to the black round rubber washer?
Yeah I was thinking of pasting the fibre washer it's only thin but is the correct size and putting some PTFE around the thread.
Yeah Kozak I noticed them didn't know if they was any good. Spose if it seals the outside in the nut then that's ok. Thank you everyone very much appreciated 🙂.
toolstation sell the rubbers separately for about 50p a pack.
ptfe round the thread is all you need and as said...they wont fit 22mm
I see them now there called ball valve washers 68p for a pack of two in toolstation.
3/4 caps only fit m/i threads but you can get blanking caps for fittings as well which normally have the rubber in as said washmac hose rubber or tape
The 3/4" blanking cap was a good fit on the valve the 22mm was too big. Yeah iv found the 3/4" rubber washers in toolstation now.
Reply to the thread, titled "3/4" blanking caps" which is posted in UK Plumbers Forums on Plumbers Forums.
Dannyparty92,
Dannyparty92,
