3/4 shower mixer to 22mm tap conn problems
View the thread, titled "3/4 shower mixer to 22mm tap conn problems" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
An old thermostatic mixer I want to reuse has 3/4 bsp inlets, with inserted non return valves. All the 3/4 to 22mm tap connectors I look at seem to have a protruding section to fit inside the 3/4, but the nrv which is of equal diameter to the protruding section, means they just sit against each other. Originally the mixer had 15mm reducing elbows on the inlets, and the 3/4 part of the elbow sat flush to the diameter of the mixer thread (albeit with a fibre washer sandwiched inbetween).
Will the tap connectors I have mentioned create a watertight seal, or is there a 3/4 to 22mm tap connector available (elbow if poss) thst would sit flush?
Many thanks
Pics attached of mixer, original elbow, and tap connector.
Thanks.
Reply to the thread, titled "3/4 shower mixer to 22mm tap conn problems" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
AdTee,
AdTee,
