View the thread, titled "3 Port Valve Life Expectancy?" which is posted in Central Heating Forum on UK Plumbers Forums.
obseen16
Hi Guys.
Been to see a customer today who has a 3port valve that is passing hot water through to the ch when on hot water only mode, this valve was only replaced 3 years ago. its a tower 3 port valve, (are tower any good?)
also its fitted so the valve is on its side. i.e its T shape is rotated 90 Degrees and fitted vertically, does that affect the life of the valve, i always fitted them so they were in the T position.
but either way 3 years seems very short for a valve.
there is probably no inhibitor in the system which gas furred up the valve seat causing it to pass
As said,system probably dirty
Thought you were going to ask about heads
When they came out ,they would last for years and years,then they made the head removable,so not need to drain and they lasted 8 to 10 years,then they made the syncron motors availible and now they can last 4 to 5 years
Keeps us in work
What I have noticed about the valves,is that I only use the ball type on bigger systems as have found the wedge shaped port closers seem to swell up and cause a restriction through the heating side
This can happen to the best of them, often due to a dirty system, try removing the head and with the system running, operate the valve with a pair of pliers, you may be able to knock the dirt out. Another thing to check is: if the pump is close to the valve, is it on max speed, reduce speed to medium speed if possible.
Martin
Reply to the thread, titled "3 Port Valve Life Expectancy?" which is posted in Central Heating Forum on Plumbers Forums.
