View the thread, titled "3 quickies" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Barry98
firstly i have only been abusing the forums since before crimbo and more often then not have always fournd my answers by searching , but not today. just finished my written papers on my ccn1 and do the pratical tommorow with the exeption of 3 questions i have got wrong. i have tried to not ask questions as i want know my stuff and not be some jet set fly by who earns 55k + in my first year (like evrone knows we all do 🙂 ).any help is greatly appreciated and when ive been out the doing it on mi tod for a while i will help other on hear. so hear goes
1 A GAS APPLIANCE INSTALLED CORRECTLY TO THE CURRENT RGS & STANDARDS SEVERLEY SCORCHES A CUPBOARD WHICH WAS LATER INSTALLED BY THE CUSTOMER. THE REGULATION NOW CONTRAVENED IS
A 3.1
B 7.1
C 8.1
D 26.1
2 BEFORE BEEN INSTALLED NEW APPLIANCES SHOULD CONFORM TO
A GSA SAFTEY (MANAGEMENT) REGS
B GAS ACT
C GAS SAFTEY (INSTALLATION & USE) REGS
D GAS APLLIANCE (SAFTEY) REGS
3 THE GREATEST ALLOWNACE FOR VARIATION IN MOVEMENT BETWEEN A BRICK EXTERNAL SKIN AND A INTERNAL TIMBER WALL ON A MULTI STOREY BUILDING WHEN INSTALLING A GAS PIPE THROUGH THE 2 SECTIONS IS FOUND
A AT THE BASE OF THE BUILDING
B ONE THIRD THE WAY UP FROM THE BASE
C HALFWAY UP FROM THE BASE
D AT THE UPPERMOST
Ive highlighted what i think but its been a few tough old days and im hoping to look back in a few days when ive done and think im such a wolly it was obvious .
again many thanks
i dont have time to look, but i'm sure No1 will be reg8.1 (i'm sure this refers to alterations to a property which effect safety) i agree with the other 2, although i have never seen a question like no3 before
I make 0 out of three I am afraid
Q 1..is 8.1 as said
Q 2.. read question,we are looking pre fitting and the appliance standards
Q 3.. least movement at ground level so ....
Hope helps,not giving direct answers as will not help 🙂
A little advise when you are doing questions,there are so many you can become brain dead,if you come across one that does not seem to make sense,leave it and come back to it,also do not do questions in order,they are doing them now, so you have to keep going back and forth the reg book to check, if not sure ,as they are looking for you to be able to look up required regs on the job when needed.
For assessment pick the section,say ventilation ,then find all questions on ventilation,read all the questions on ventilation briefly,read through section and answer as you come across question ,then all on Combustion ect,then go back and mop up
c,c,d.
(2?) part e 27(1)?
but iam one step behind you.
blow me... i may have got them all?.
A little clue
Appliances and fittings to satisfy the essential requirements and to be safe
7.—(1) No manufacturer or his authorised representative established in the Community shall supply an appliance or a fitting which does not satisfy the essential requirements.
(2) No person shall supply an appliance which, when normally used, is not safe; and, in this paragraph, "normally used" in relation to use means use—
This is not from GAS SAFTEY (INSTALLATION & USE) REGS 😛
We have not got to the installation bit yet
i am pannicking now piddle,
where on earth does this info come from?. i cant find it any where in my book...
at this rate i have no chance!!!
got all interested then,3 quickies thought the answers were 1,blonde 2,brunette 3 big twitts?
the answers were c,d,d
but more importantly i passed. i would publicly like to thank everyone on the forums whos posts i have read to help me understand stuff i didnt. i look forwad to the real hard work now of actually putting all this into practice and getting some experience. cheers
😛 oh well i knew No1 and guessed the other 2 (badly it would seem), have never seen this type of question in all the ACS stuff i have seen or perhaps it was the way they were written (thats my excuse anyway) what do i know i only work as a gas/plumbing lecturer😕
Well done bod
Am sure with your attitude,think you are going to make a good contribution to the industry
now,if you have time,I have this boiler and the gas rate is not quite right and was wondering ...................🙂
good luck !!
Well done bod
good luck !!
you was wondering if i knew anyone who could help you out ?
thanks fella looking forwad to the grafting bit now
Question one i dont know. should be in the blue book though with a funny pattern on the front, holds all the regs in.
Number two states in the question that its before installation so the reg in force won't be the installation and use. (easy mistake, its the way the question is and just flying trough the question sometimes miss the obvious clue)
Number 3 is a pain in my rear end, i had this question on my ACS in October and when i read it just then i got 5 words in and knew the rest. I beleive from memory its the last one, highest point.
Reply to the thread, titled "3 quickies" which is posted in UK Plumbers Forums on Plumbers Forums.
