3 showers at same time?
View the thread, titled "3 showers at same time?" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
W
WPB
I have a 5 bed house with a 5 yr old Baxi Combi 105e boiler that feeds the radiators and hot water.
Main bathroom has a Mira Sport Max Electric shower - no problem
Two en-suites have Aqualisa Quartz showers fed from the boiler.
What do I need to do in order that any one can use the showers at the same time and have hot water.
I have had so many different answers.
Water board have checked supply and we have a flow rate of 14ltr per min and 2.5 Bar Pressure to the house. A new mains pipe was laid to house 5 yrs ago when extension was built.
If you are struggling for enough hot water at the moment, the simplest and cheapest thing to try first is to put flow restrictors in the hot and cold supplies to the mixers fed off the boilers. THese are little plastic things which go in the pipework and reduce the flow rates.
worst case scenario if you must run 2 showers at once, replace one for anther electric or add an unvented cylinder to be heated off combi primaries and leave kitchen and one bathroom on the cobi hw supply and then repipe other bathrooms to the unvented cylinder, then happy all round, need an s/y plan set up andsome changes to combi programmer/wiring for it to work ok
Once again, Oldplumber is spot on. I have done exactly what he suggests. It works a treat.
As in run an unvented, heated from the primary side.
It was years ago, and my father wired it up, not me. They were seriously chuffed with the result.
I am grateful for help so far. I have called 5 plumbers, 2 never even came back to me, 1 looked and said I needed a tank(think it had another name) commanly used on the continent that has a diaphram that pushes the pressure up but never came back to me despite 2 calls, one has said a cold water tank & immersion and last one said too reduce the water coming into the Aqulisa processors by turning the valves on the cold and hot inlets a little. This last one suggestion seems to work when you turn both Aqualisa's on they produce a flow of hot water. Excuse my ignorance but is this what you are meaing by the prv's. I have sought professional plumbers and been utterly bamboozled by the array of different answers and just trying to understand.
Will reducing the water into the Aqualisa's be a problem?
I am grateful for your advise guy's.
Reply to the thread, titled "3 showers at same time?" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
WPB,
WPB,
