3 wires from cylinder stat to programmer wiring help with pics
View the thread, titled "3 wires from cylinder stat to programmer wiring help with pics" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi
Just had a new boiler system and smart programmer fitted (salus IT500)
Plumber wasn't to sure if the stat was wired correctly as he wasn't clued up on smart programmers .
Everything works fine on the new system apart from when it calls for heat it don't like it and I have to put it on manual .
At the time we didn't have the pinout of the stat (old Landis & GYR) but now I have found them (below)
Easy question I have put both pinout of stat and the salus programmer box can you tell me where the 3 wires go from stat to box (3 black wires shown on diagram )
He cant come back for 4 weeks and need it sorted
Thanks on advance
Update
OK I'm sure the stat is wired correctly now, it's behaving a bit different now .
CH works fine that kicks in when switched and turns off fine
HW this run back to front , when I call for it it switches off , when I turn it off on the smart controller it switches on
So it all works fine apart from hot water is back to front
Reply to the thread, titled "3 wires from cylinder stat to programmer wiring help with pics" which is posted in UK Plumbers Forums on Plumbers Forums.
Roosie,
Roosie,
