32mm MDPE supply pipe upgrade for flow?
View the thread, titled "32mm MDPE supply pipe upgrade for flow?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello all,
Currently suffering from poor internal flow rates near the internal 20mm stopcock of 10L/min.
Want to upgrade system to either unvented cylinder or large storage combi to feed 5 bedrooms/1 bathroom/1en suite.
Affinity water have confirmed supply pipe to the boundary stopcock is 25mm mdpe as part of the lead replacement scheme.
House was extended 20 years ago and 20mm MDPE going into the existing stopcock which goes into 15mm/22mm copper around the house.
It is possible we still have a lead supply pipe and was extended to the new stopcock position in 20mm mdpe but unsure.
Flow Rates:
Boundary
40L/min
2Bar static
Garden Tap
2 Bar static
15L/Min
Kitchen Tap (next to 20mm stopcock)
2 Bar Static 10L/Min
Upstairs Taps:
2Bar static 8L/Min Flow
My question is would upgrading the existing 15mm/20mm supply pipe to 32mm MDPE help increase the flow (considering boundary is 40L/min)??
Cheers,
Dave
How do you know it’s 40 lpm at the boundary, have affinity confirmed this? If you’re getting that much of a reduction, then it suggests to me that something is causing a lower flow rate, although the pressure seems to remain constistant.
Yes Affinity water confirmed it and I witnessed it. So could it be the old lead pipe/20mm
Mdpe extension causing it?
Reply to the thread, titled "32mm MDPE supply pipe upgrade for flow?" which is posted in UK Plumbers Forums on Plumbers Forums.
Cockneydave,
ShaunCorbs,
