32mm MDPE to 2 x 22mm?
View the thread, titled "32mm MDPE to 2 x 22mm?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi All,
Having a new extension built, the water main from the street has been replaced with 32mm MDPE.
Currently have a 15mm pipe that feeds the house from the stopcock and get interaction between appliances (shower drops flow when washing machine fills etc) - shower is fed straight from combi.
What is the best way to distribute new pipe through the house to reduce interaction between appliances.
My thoughts are to use 2 x 22mm pipes - one straight to the boiler and the other to supply everything else (reducing down to 15mm or even 10mm)
We will have 3 bathrooms (doubtful that they will be used at the same time) - I want to future proof as much as possible for when or if we upgrade to a bigger boiler and / or pressurised cylinder etc
Any advice?
32mm to 28mm plasson adapter.
28mm to unvented (if that's the way you go) with a 28mm balanced cold. Use a 28mm pressure reducing valve to maintain flow rates.
Then appropriately sized pipes to outlets, with 22mm to showers if they require high flow rates.
Reply to the thread, titled "32mm MDPE to 2 x 22mm?" which is posted in UK Plumbers Forums on Plumbers Forums.
Wozza,
fezster,
