View the thread, titled "a few questions from my gas training" which is posted in Gas Engineers Forum on UK Plumbers Forums.
It not only depends on the meter size but also the pipe size . You need to learn these and get them into your head. It is only 6 numbers. No one will be impressed if you have to look this up.
0.25mb is perceptible movement (readable movement) on a U guage or an electronic to 2 dp's (0.2mb if it reads to 1 decimal place)
i will advise the customer the drop is within tollerance and ask if they would like me to find the leak and fix . personaly but its just me i like to find any leaks but not always practable.there is no legal obligation to disconnect the appliances and test if its on the pipework only - but if you do and it is on the pipwork you are then committed to find and fix . as for the drop 8 or 4 depends on th meter fitted
8, 4 and 1 for an E6 (or pipework and appliances after an ECV (or AECV) if no meter) a U6/G4 and a U16 if pipework is 28m or less.
If any pipework is above 28 up to 35mm the allowances are 4.5, 2.5 and 1
It is only 6 numbers but they are important ones so remember them
cheers everyone,
I think I have got my head round it all now,
(did it the next day but have moved)
It all depends on the appliances connected, meter, the u gauge you use and what you are happy with.
will keep going over these, thank you all
Reply to the thread, titled "a few questions from my gas training" which is posted in Gas Engineers Forum on Electricians Forums.
