A leak I cannot get to! What to do in this situation!?
View the thread, titled "A leak I cannot get to! What to do in this situation!?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi All,
I've discovered a leak somewhere related to the cistern to a toilet upstairs which is hidden behind the tiled wall. I cannot be specific at where this leak is coming from, because the access to it is really restricted. Taking off the wall flush plate, I can get my arm into the area, and can feel that the higher pipe (feed pipe?) seems totally dry, but as I stretch around behind and under the cistern, I feel a lot of wetness. It's ended up dripping through the ceiling into (by chance) the toilet on the ground floor. I've emptied the cistern and make it so it doesn't refill. The dripping/leak has stopped. I'm pretty sure I need someone who is familiar with this setup and how to fix it, but I thought I'd double check first, in case there is something obvious I'm missing regarding how the hell would anyone (a plumber or myself!) would access this kind of setup?
TIA
Ok, thats what I feared. Thanks for your responses @ShaunCorbs and @gmartine
I bought some of those seals that sit at the base of the flush unit (its Ideal standard) to replace on other toilets that were leaking constantly into the bowl, so might that be an option to replace? Or is that not likely to be the cause?
No as you shouldn’t have water on the outside of the cistern / below
One option is to remove the toilet pan and cut a hole the same width as the toilet -1” eg so it covers and see if a plumber could work with that not easy and prob won’t be cheap because of pita to work on etc but might be doable
Damn it. ok. I did try using my iPhone and Apple Watch as a remote, so I could try and see what's going on, but was worried I might drop the iPhone, then the bill would be even more! So I think I'll invest in one of those endoscope cameras. Anyone got one they'd recommend?
I bought a cheap one from Amazon...they are not very good, quite difficult to control accurately but probably good enough.
I'd very securely elastic band your phone to say a kitchen spatula, tie a bit of strong thread to that and run that outside the cavity incase you drop it.
Reply to the thread, titled "A leak I cannot get to! What to do in this situation!?" which is posted in UK Plumbers Forums on Plumbers Forums.
Audiotechnical,
MikeJhn,
