A23 Ariston Ignition Lockout
View the thread, titled "A23 Ariston Ignition Lockout" which is posted in UK Plumbers Forums on UK Plumbers Forums.
L
Lintscore
Hi Guys
The hot water seems to run Ok.
When I turn the central heating on after a while the Ignition Lockout light comes on. This happens each time, otherwise the boiler works fine
I have checked the resistance of the thermistor/thermostat and it measures 13.96 K Ohms.
There is also a small leak in the area directly below the diaphragm, seems coming from the diaphragm.
Any advice please.
Thank you.
:santa3:
this plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
if you are gsr then message gasman , redsaw or croppie thanks
Reply to the thread, titled "A23 Ariston Ignition Lockout" which is posted in UK Plumbers Forums on Plumbers Forums.
Lintscore,
Barry98,
