Although that document has a lot more information in it and is better organised than the On Site Guide I have been working from the information regarding the horizontal minimum is the same.
Are you saying that it is not 1500mm and should be 600mm?
Also in that document are the exact same tables and diagrams of dimensions regarding Open Flue Terminal placement and minimum clearances that are in the "On Site Guide" I referred to earlier.
Am I incorrect in saying that you don't insulate a single walled flue in an external environment? By the document you linked installing a single walled flue is an absolute no no in external environments so B) is even more wrong.
I'm not gas safe yet but there is definitely something wrong here. Either "I don't get it" in which case I`m in serious trouble or something else is wrong in which case I`m in trouble anyway 🙁
