View the thread, titled "Adding a booster pump to a secondary system" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I think the point is this doesn’t add up. The cylinder that we’ve seen the top of will not have the capacity to feed three bathrooms I can’t believe this has ever worked
Are you a plumber?
No, and have never pretended to be on here. I have a building contract company and have a plumber that is away over Xmas. Needed to see if I can get hot water pressure in short term before putting in an invented system.
Will the cyclinder not work due to the capacity?
Should be fine if you run one bathroom at a time but won't last with all 3 going at the same time less than 5 mins on full load
My advice would be get G3 qualified engineer in after the festive period as this isn’t fixed just with a pump in fact you are exacerbating the problem and using up hot water even quicker. There’s much more to it
This is the comment I made earlier. Sometimes the only option is an expensive one. What is the pressure both static and dynamic? you need this info before you know if unvented is viable and recorded at different times of day and especially at times of high usage in the area. You may need an accumulator too. The answer can be quite complex and there are lots of things to take into consideration that may not be obvious to none plumbers. The hot water has been under gravity for years and then you are pressurising it and this can lead to problems not caused by but exposing issues that have been there for ages.
Reply to the thread, titled "Adding a booster pump to a secondary system" which is posted in UK Plumbers Forums on Plumbers Forums.
