Long time no see….
A follow up to this rather old thread;
Thread 'Radiator not heating up as quickly as others?'
Radiator not heating up as quickly as others? | Plumbing Jobs | The Job-board | Plumbers Forums - https://www.plumberstalk.net/threads/radiator-not-heating-up-as-quickly-as-others.99456/
Where the problem was that I, as an uneducated cretin T’eed off 10mm micro bore heating pipe to add 2 radiators. Was told it was wrong, and should have gone back to manifold.
Fair do’s… I made a mistake.
Next years project in the house will be to reposition the bedroom radiator… which means this T off will be one rad less on the branch…. However, I want to hang the radiator on the other side of the bedroom, back to back with another bedrooms rad.
Is it daft to just T off the back? I know, I could end up with the same problem…. But it would be easier than piping back to the manifold.
I will also be changing the en suite bathroom radiator to a towel rail, with possible a built in electric element (do you guys rate than much?) and electric UFH
