Hi, I would be grateful for advice regarding how I can recharge a water hammer arrestor.
Background:
Just over 2 and a half years ago the old gravity system in my medium sized 3 bed semi was converted to a pressure combi-boiler system by British Gas. Immediately after this I experienced water hammer in my pipes (something I had not experienced before). I complained to British Gas and they installed a water hammer arrestor, which significantly reduced the problem. However, the arrestor now seems to be failing as I am again hearing a heavy clunking sound in the pipes whenever the toilet cistern is filled after flushing and whenever I turn off my taps after running water from them.
The arrestor is located on the cold water feed that leads to the combi-boiler (a Baxi). The boiler is situated on the first floor landing in my 'airing cupboard', which used to house the old gravity system's hot water cylinder. The arrestor is positioned about 18 inches below the boiler.
The airing cupboard is right next to the bathroom and it also houses the electrics and plumbing for an instant shower over the bath.
The arrestor was installed by British Gas to stop all of the taps in the house - both hot and cold - from clunking, i.e. kitchen sink, bath and wash hand basin taps.
The arrestor also reduced somewhat (but not totally) the clunking heard when my washing machine stops filling and when the toilet cystern stops filling.
The arrestor also stops cold water from shooting out of the instant shower above my bath. (I'm not sure, but if my memory serves me correctly, this used to happen either when the taps in the kitchen were turned on and/or when the toilet cystern was filling - It's not happening at the moment, but I think it's only a matter of time before it happens again.)
A picture of the arrestor can be seen by clicking on the following link or putting it into your browser if that doesn't work (sorry, I tried to upload an image, but it was not successful)
[DLMURL]http://tinyurl.com/mky564g[/DLMURL]
British Gas didn't leave any manufacturer's instructions/details about the arrestor and I don't know its make. It looks similar to others that I've seen on the Internet, which are pre-set to 3.0-3.5 bar with a capacity of 0.16 litres. (Its size is just a bit larger than a tennis ball.)
Questions:
How do I do the recharging? What process do I go through?
Do I just simply turn the water off at the stopcock and run all of the cold water taps to empty the system first and then add (pump) air into the arrestor?
I've read elsewhere on the Internet that the arrestor could be recharged with a mountain bike shock pump, which I understand would have the advantage of not letting any air escape during the removal of the pump after recharging; would it do the job?
If after recharging the arrestor should fail again, would it be best to get it replaced with a mechanical arrestor? Would a mechanical one do the same job, and what type and make would be advisable?
If I were to get the arrestor replaced with another chamber arrestor, am I likely to get longer service life with a more expensive one? (They seem to range from about £20 to £40.)
Many thanks if you can help.
Background:
Questions:
