J
Johnstephen
Hi all,
am wanting to purchase and fit a couple of two way valves.one for dhw the other for rads.
am an electrical engineer by trade and have the required skills and knowledge
etc to safely shut down the system and drain it down.
once plumbed in I will be wiring in myslef.
Could you guys please recommend
a)suitable 2 way valves ,preferably the type that can have the motors etc replaced without having to remove the complete valve.prefer good quality rather than cheap and cheerful.
b) a suitable wiring diagram for the boiler( conventioNl heat only gas ideal Mexico) the two valves, two pumps one for dhw the other for the rads,tank thermostat
c) intend using the bg hive unit as room thermostat and program unit.
system is conventional hot water tank in loft,indirect with open vent.
Could I finally ask,should the valves go on the flow or return to the boiler ?
Regards,
johns
Regards,
johns
