Advice on faulty water underfloor heating system
View the thread, titled "Advice on faulty water underfloor heating system" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello all and hope everyone is well,
New to the forum and would be very grateful for any expert help.
I live in a small flat that has underfloor heating zones in living, bedroom and bathroom.
Unfortunately, the floor no longer heats up when I activate the bedroom and living room zones. However, oddly, the heated towel rail in the bathroom gets extremely hot, like all of the systems efforts are going to it.
I have attached some photographs showing the underfloor heating system set up. I have a valliant eco tec pro combi boiler, and the UFH system is by Heatmiser.
Each thermostat is correctly paired with the wireless receiver, however I did have an issue with some faulty batteries in each thermostat that required me to re-pair each thermostat to the receiver. This was quite a while ago and i couldn’t say if this is when the general system stopped working.
Any help would be hugely appreciated. Would be excellent if I could fix the issue myself although happy to get an expert in if required.
Many thanks.
Dylan
From off take a picture of the flow meters eg with no zone calling
Turn one zone on and do you see the flow meter move down ? Test the other zones the same
Hi Shaun,
Thank you very much for the quick response.
I attach photographs labelled as:
no zone calling
zone 1
zone 2
zone 3
I let each zone heat up for around 5 minutes before taking the photographs.
and then waited a couple of minutes before putting another zone on.
hope the photos are clear and thank you in advance for any input you can provide.
Dylan
I suspect zone 1 and 3 are linked maybe a big room
2 is an independent zone
All looks to be working tbh and with the manifold moving 80 heat the floor should warm up might take a day to fully warm up
Reply to the thread, titled "Advice on faulty water underfloor heating system" which is posted in UK Plumbers Forums on Plumbers Forums.
Dylan Woods,
ShaunCorbs,
