Advice on replacing Central Heating Room Thermostat
View the thread, titled "Advice on replacing Central Heating Room Thermostat" which is posted in Central Heating Forum on UK Plumbers Forums.
Solorize
I would like to replace my existing manual room thermostat which is a “Danfoss Randal RMT 230”,
but could do with a bit of advice.
Due to the current location of the existing unit, tight up against my sitting room door! I could do with
a bit of advice on which model I should replace it with and which would work with the current wiring
(which is shown in the images below).
Due to the location, as said above, is next to a door and in close proximity to my TV unit,
would I be better to go for a wireless unit? (price dependent).
I would preferably like to go for a electronic 7 Day programmable room thermostat.
Also, the hole in the wall that the existing unit fixes badly into, is 80 x 80mm so would the new unit
would need to cover this up, but still be able to fix onto the wall, I may have to turn the new one
90 degrees (i.e. mount it vertically) so that it can cover up the hole.
Please note I will be attempting to install the unit myself, so needs to be simple =)
Also is there anything else I will need to look out for i.e. matching voltages etc..? and would my
type/make of boiler make any difference in which one I should go for?
FYI.
My boiler is: Glow-worm Ultimate 50 FF Non-Condensing Gas Conventional (Regular) boiler
I would be willing to spend approx £100 max on the new unit.
Any advice would be greatly appreciated.
Images of current unit:
Current wiring
Wiring diagram
overview of location
Boiler
Thanks for your reply.
I am swaying towards the Honeywell 727.
Someone else i've been speaking to has recommended this as I will be able to have the thermostat
located in a different position.
i would not go wireless sick of changing batteries.i moved mine when i was about to decorate.
lol, why is that? I have fitted quite a few and never had any problems, yes that are cheap and abit nasty but they have always done that job.
Go the Honeywell route either fixed (CM907), or the CM927 Wireless.
I've fitted both, for myself CM907 (Incidentally within you're Budget) and the Wireless for my daughter; who had no existing thermostat
fitted to her system.
Both straightforward from the Honeywell instructions and Boiler Info Manuals.
PS: Boiler Info and Honeywell Manuals available on line
These digi stats seem to go wrong all the time, does anyone know of a reliable one. Seem to replace the Drayton receivers a lot.
Can't beat a 240v stat IMO it just needs to be in the right position.
See this posting from another thread based on our in-warranty returns. It surprised me.
Ray Stafford said:
Its a good point about RF controls.
I just looked up our return rates - we sell 1000s of RF controls, so our in-warranty return data should give a good feel for reliability.
Return rate on Drayton RF products - 2.03%
Return rate on Honeywell RF products - 2.19%
Here's the one that surprised me:
Return rate on Salus RF products - 2.8%. I would have expected a bigger gap between the "budget brand" and the quality boys.
For comparison, the return rate on hard-wired products is usually 1% plus or minus 0.2%.
Reply to the thread, titled "Advice on replacing Central Heating Room Thermostat" which is posted in Central Heating Forum on Plumbers Forums.
Solorize,
Roger Welton,
