UK Advice on waste water pump in first floor flat
View the thread, titled "Advice on waste water pump in first floor flat" which is posted in Bathroom Advice on UK Plumbers Forums.
UK
Sorry if this is stupid question.
We have waste water pump in our first floor flat (not sure what it is called)? It failed and wouldn't drain waste water from shower, we found out too late and the water had drained through the ceiling into the property below us.
Probably a bit of stretch but we'd like to know if there is way of knowing if the pump fails or is off for some reason so we stop using water. Can the water be stopped automatically?
Some of them have an alarm that goes off when the pump fails.
- Optional extra when purchasing pump.
Optional extra costs @ 20% of the pump.
That's why plumbers or Property Owners don't want them installed.
There are 2 ways to know a pump has failed.
1/ the way you found out.
2/ put an alarm on the pump. ( hopefully the alarm works )
If a property needs it, it has to be installed
It doesn't always work that way.
Property owners. Landlords, Builders, Developers are always looking at reducing costs at whoever's detriment down the track.
Plumbers also don't know or don't allow for extra things required on some jobs.
Who knows what the situation was on your job / place
Reply to the thread, titled "Advice on waste water pump in first floor flat" which is posted in Bathroom Advice on Plumbers Forums.
kbqwert,
oz-plumber,
