Air admittance valve, will it help
View the thread, titled "Air admittance valve, will it help" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Skinszo
Hi all,
I've just been to look at a job, the customers shower trap has got air coming up so I'm assing there's no u bend.
There is no way of getting to the underside of the tray without major works as it's stuck down onto a basement floor, tiled all around.
I can can get access to the basin waste and the toilet wastes by cutting a hole on the other side of the wall in a bedroom, and both of these are higher up than the shower.
Nothing appears to to have an air admittance valve installed and I'm wondering if I installed these on the loo and basin if it would stop air coming through the shower .
Im guessing you mean its bubbling up?
The tray will be trapped and as you mention its in a basement the top of the stack should be vented so if the stack goes up to serve another bathroom it may be vented up there.
I would look to see if the drain is partially blocked, if not i would say its probably a pipework issue, waste pipes tee'd together or compression at the bottom of the stack if it carries on up to other bathroms.
Reply to the thread, titled "Air admittance valve, will it help" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Skinszo,
josh,
