View the thread, titled "Air Admittance Valve" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Driver
We have an air admittance valve on the top of a waste stack outside a first floor a bathroom. The valve is about 50cms above the waste inlet from the toilet. This has been there for 20 years plus and has never been a problem. About a week ago when the toilet was flushed the water rose up the bowl but did drain out quickly. I thought we had a blockage and used a plunger to no avail. Since then I've had 2 plumbers look at it who both used a plunger again to no avail. However the second one took the air admittance valve off the stack and then when the toilet was flushed it emptied as normal.
I have now bought a new valve but the problem remains the same. With the valve off the toilet empties normally, with it on the water rises up the bowl.
Any suggestions anyone.
Nice one chris, quite right. I was wrongly under the impression that an AAV has the ability to vent if experiences a high level of positive pressure (I must have stuck my pinky in the wrong way when I defiled my last aav). I do understand as stated in my op that there primarily for letting in air. There are PAPA Positive Air Pressure Attenuators for dealing with these situations
Reply to the thread, titled "Air Admittance Valve" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
