View the thread, titled "Air in system" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
F
ferrytrip1
Hi, we had pump, 3 way valve replaced before xmas. One radiator needs constant bleeding so I assume air must be getting in from somewhere.
Is this a valid assumption or is it possible that the systems is still trying to purge the air and it is settleing in this one rad.
If air is getting in - how would I trace the entry point?
Simon
sounds like a high point in the system pipe work on that rad or a corrosion problem try setting fire to the air carefully if it burns you have corrosion issues also check your pump see what duty it is and speed its set on
hmmm, set fire to it - think i'll pass and seek assistance with that one. Pump is on its lowest setting, no it was ok prior to the work. Would a loose joint let air in rather than let water out?
Prior to the work the system was filled with the stuff to loosen any sludge, after the work a corrsion inhibitor was added.
I will be replacing a bath towel rad next week so will look at the joints then
Thanks for the replies
Simon
Reply to the thread, titled "Air in system" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
