Air in the system
View the thread, titled "Air in the system" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
L
lenny
Hi
Having a bit of a nightmare getting a radiator hot. It is on a closed circuit , its the last one on the circuit and the routing to this radiator doesn't particulary help !
I am convinced that there is air stuck in the pipe.
Anybody got any good tips on how to release it ?? 😕
Len
Open valves fully on the problem rad and turn everything else off, boiler on full, pump on full and this normally clears air or blockage.
Still no luck in getting the air out of the system, the rad valves are new is it possible the rad valve could be broken in the closed position?
Any more ideas???
thanks
Len
If it is not a combi check that there is water in the F & E tank in the loft ?? Check valve on ballcock has not stuck so that there is no water available to top up the system to replace the air you are trying to bleed. It happened to me.
If thats the case disconnect the radiator valves one at a time with a bucket under and turn on, be careful and only do one at a time and run to see if any air or sludge.
Easyt
OP said its on a closed system.
Eco
Hi
Len
If you've checked the valves & they are ok, I'd isolate the rad valves & see if its sludge been dumped in the last radiator. There are a lot of instances where open vented systems are converted to sealed systems without a system clean. Might be a bit late as I notice this thread is 2 weeks old 🙄
Reply to the thread, titled "Air in the system" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
lenny,
AndyBeeApy,
