View the thread, titled "Air Lock Help Please" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
PlumbersMate
If i want to blast cold mains back up the hot tap whats the best thing to use to connect the cold tap to the hot tap? Thanks in advance
easiest way is to connect hot to cold on washing machine connections, turn on hot then cold for about twenty seconds should do it.
you connect the two feeds for the washing machine together at the valves under the sink or where ever they are, using a spare w/m hose or one off the w/m. turn the hot on first then the cold. blast for about twenty seconds then turn off.
Reply to the thread, titled "Air Lock Help Please" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
