View the thread, titled "Air lock ?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Paul C
Hi I drained vented system down to replace a rad now filled up and bled pump and rads. Boiler ( oil) fires up and the central heating outlet is cold & pump is running. The feed pipe to the hot water tank is scalding hot but then no water is getting to the storage tank. This water is so hot it then turn the boiler off so my central heating is cold. Do I need to drain down again will this help? How do I fill up again and stop this happening ?
Reply to the thread, titled "Air lock ?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
