Discuss Air source heat pumps and hot water in the Renewables area at PlumbersForums.net
J
john69
Hi
Can somebody tell me if a standard heat source pump installation uses a pressurized hot water tank? Or will the pressure for the hot water be the same as with my oil boiler and water storage tank (gravity-fed)?
They will change the cylinder there’s no need to go pressurised upto you to say you want gravity hot water or mains pressure etc
Reply to Air source heat pumps and hot water in the Renewables area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hi, I am currently using a Grundfos Booster Pump. This pump is fed by 2pcs of 1,000 liters water tank. Normally the pump would stop working...
