View the thread, titled "Air vent screw help !!!" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Morning all I have main boiler could you tell me from the photo is the black screw suppose to be open or tightly closed don’t know what is best
When you open it, as Shaun says, just a turn or so, listen carefully to it. Close very gently when the warbling stops. Don't rush. You may well get a few drops of fluid. They can dribble so close when you are done. There is a float inside operating a valve, so how well the valve seats depends on the pressure in the system. It's an AAV.
Cheers, Roy (Amateur plumber)
Reply to the thread, titled "Air vent screw help !!!" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Thread starter
Joined
Location
Nottingham
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
vent
Gibbo1471,
Roy_66,
