Airlock in twin radiator.
View the thread, titled "Airlock in twin radiator." which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Twin rad with only waterways at bottom. Each half has its own bleed valve. Back heats up front does not surely must be a blocked bleed valve?
Possibly ? or a blocked waterway in the rad, try turning all your radiators off except that one and let the system run it may clear it . Then reintroduce the other rads till all back online . Kop
Reply to the thread, titled "Airlock in twin radiator." which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Bogart,
moonlight,
