Airlock open vented system?
View the thread, titled "Airlock open vented system?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
L
lndwl3
Hello new to the forum Hope someone can help please.
New gloworm flexicom 18hx fitted last year,not much problem with the boiler until changed out pump and replaced rad upstairs i thought i take the opportunity to drain down and flush the system out at the same time.Bad mistake i think, because the boiler fires up and cuts out on fault code F22 (Low water pressure,not enought water in the system the user manual states a couple of other possible causes ie flow and return thermistors but this maybe because its nots seeing any temperature difference.
I have tried various remedies that have been posted on site for airlocks but cant shift it
Any advise would be welcome,Thanks
Reply to the thread, titled "Airlock open vented system?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
lndwl3,
lndwl3,
