Balmoral
Should their be an aav on the flow and returnits an openvented system cant seem to get air lock out I
Small squirt of washing up liquid shot into f/e tank cold feed, let it pull into system, and run round primary circuit only as you've got to rinse it all out afterwards, if doesn't work first time try a little more, this does work and has helped loads of engs. I know, taught to me by my dodgy master when I was an app 22 yrs back
It will get rid of airlock, it works, no kidding
Just try it or don't but it'll get you home quicker next time you have one
just pull out the thermostat on the boiler and let it warm up for a bit then pop it in an let things settle, dont even need to climb a ladder 🙂 only for the brave and the customers gone out, can be a tadge noisy 🙂
Then forget about it then, your loss
cant see washing up liquid working. other than bubbles in the f and e
wouldnt reccommend boiling a lwc boiler either, only a nice big cast iron one 🙂
Muppet with a quick solution, mug
Bet you think about this next time though, hey? You know you will! Then think of all the hours wasted lol
Reply to the thread, titled "airlock" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
