B
Balmoral
Should their be an aav on the flow and returnits an openvented system cant seem to get air lock out I
Small squirt of washing up liquid shot into f/e tank cold feed, let it pull into system, and run round primary circuit only as you've got to rinse it all out afterwards, if doesn't work first time try a little more, this does work and has helped loads of engs. I know, taught to me by my dodgy master when I was an app 22 yrs back
It will get rid of airlock, it works, no kidding
Just try it or don't but it'll get you home quicker next time you have one
just pull out the thermostat on the boiler and let it warm up for a bit then pop it in an let things settle, dont even need to climb a ladder 🙂 only for the brave and the customers gone out, can be a tadge noisy 🙂
Then forget about it then, your loss
cant see washing up liquid working. other than bubbles in the f and e
wouldnt reccommend boiling a lwc boiler either, only a nice big cast iron one 🙂
Muppet with a quick solution, mug
Bet you think about this next time though, hey? You know you will! Then think of all the hours wasted lol
You can get it in quick enough and it will clear an air lock in around 2 minutes but you can never get it back out unless you drain and refill a few times which isn't going to happen.There's no way, it would need flushing out, quick blast of mains pressure will do the trick or boiling it, or closing down rads. Far quicker than trying to get soapy water in the system and back out.
When we were doing this it was on badly piped up systems on cast iron boilers.
I wouldn't recommend doing it these days.
I saw an old boy use a large tin of beans on a big sectional cast iron boiler to stop a leak worked a treat would I do it now nooo
Strange things happened years ago. Pease brose (ask yer da) seals small leaks on water tanks too if you are stuck :smile:
It is a kind of flour made from peas mixed with oatmeal.
My granny used to make it :lol:
Not sure if you can still buy it. If you can it will probably be from some heath food specialty place with an up market price.
Reply to the thread, titled "airlock" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
