View the thread, titled "Aj gummer 1861 shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
C
caithe
Hi
We have an AJ Gummer shower 1861 Sirrus - that is dripping very badly from the head and the nut on the underside of the main unit. my husband has bought a pack of rubber circles and is going to try and take it apart at the main tape part at the front. first, does he have to switch the weater off from the main stopcock and is he ok to do it as he is not a plumber but is very good at diy.
Catherine
yes water has to go off,they can be a mixed bag in regards to dismantling and putting back together some are easy some are a ball ache ,has he bought the proper o ring set as most are dedicated
Hi
Catherine
Gas is right some are really awkward and others are simple especially when u come up against certain stupid cir clips and u cant find your circlip grips. You normally have dedicated service kits (pack of washers) as impossible to use your own o rings.. good luck.
Reply to the thread, titled "Aj gummer 1861 shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
