Hi, I have a Alpha C27 Combi Gas Boiler which has started making a squealing noise when the hot water is on, no noise with central heating. It still makes the noise when the boiler is switched off at mains and hot tap running
I have found that if I reduce the water flow at the mains stopcock the noise goes away, however I would prefer a higher flow rate.
So I would be pleased to receive your thoughts/comments to what this might be, i.e. heat exchanger/flow regulator
