Alpha CB24 gas central heating boiler leak
View the thread, titled "Alpha CB24 gas central heating boiler leak" which is posted in Boiler Advice Forum on UK Plumbers Forums.
R
robat
Hi, Can anyone please guide me > I have a water leak coming from
exactly at the DHW Flow Switch on my Alpha CB24 gas central heating
boiler, will replacing this switch possibly stop the leak. please all advice
appreciated. Thanking you rob
The dhw flow switch on this boiler is on a saddle clip clip that fits over top of diverter valve,this is not the cause of the leak and replacing will do no good,the leak will be coming from the diverter valve itself due to one of the pin seals gone,you will require a new or serviced replacement diverter valve,to fit this is not easy,well the fitting is not that bad but you will disturb a lot of other joints that will also require replacing,connections to plate heat exchanger and others
Hi, Thank you very much for your swift reply and guidance rob
Re: Alpha CB24 gas central heating boiler leak,
Hi Again, sorry to be a pain in the derier, but would i be able to buy these seals anywhere,if so could you please point me in the right direction, Thanks so much rob.
Reply to the thread, titled "Alpha CB24 gas central heating boiler leak" which is posted in Boiler Advice Forum on Plumbers Forums.
robat,
robat,
