View the thread, titled "Alpha CD18R boiler central heating problem" which is posted in Boiler Advice Forum on UK Plumbers Forums.
D Stone
Hi
Decided to test the Central Heating last night but it doesn't seem to be working.
The only light glowing on the panel is the Electical supply. The Burner light is not coming on for the central heating and there is complete silence. The radiators have been bled and are ready to go. We have checked the trouble shooting section of the manual but that only refers to a problem if the burner light is flashing!!
Strangley the boiler seems to be working fine to just to heat the water.😕
Please help!
is the three port valve moving when you call for ch mode?try putting it on manual,if it then fires up you may have a bad connection to the valve or a dodgy valve.HTH
Is the room stat RF, if so it might need retuning into the receiver. as you've replaced the batteries.
Reply to the thread, titled "Alpha CD18R boiler central heating problem" which is posted in Boiler Advice Forum on Plumbers Forums.
