View the thread, titled "ALPHA CD24C Primary pressure switch leaking" which is posted in UK Plumbers Forums on UK Plumbers Forums.
stingo
hi all newbie here.
so i have just put the central heating on and ten minutes later hear dripping water from boiler, alpha cd24c 5year-9mnth old
removed front casing to see water coming out of the pressure primary switch housing (not its seating) so a couple of questions.
1 think i got extra guarentee with this unsure at present
2 can the part be sourced locally PTS etc seen them on fleabay but could do with one tommorow
3 how easy to replace(thats the easy bit unscrew/screwin) but does the whole system need draining/flushing/bleeding etc etc
4 very competent DIYer
5 is that a common fault
thanks
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
can you read?????????????
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Reply to the thread, titled "ALPHA CD24C Primary pressure switch leaking" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
stingo,
Dotty,
