J
judsjasper
Hello all - new here and looking for some "impartial professional advice".
I have had a quote from a large installation company and have a query with what they have recommended.
I am having a new combi fitted and have been told this will be a "Baxi Neta Tec 24". I have concerns as the reviews I have read say this is suitable for a small house.
I will provide as much info as possible which I think may be relevant.
I live in a 4 Bed detached house and have 12 Rads, 1 Main bathroom (electric shower), 1 En Suite (Mixer Shower) and downstairs WC.
The water pressure is currenlty 20l/hr I beleive and i have been told this is likely to reduce with a new combi which is fine to an extent but will my mixer shower still work...?
British Gas have just been to give me an alternative quote and have said they advise a 33KW as a minimum and preferably a 37...but it's pbviously more expensive and money is tight...
Can anyone help or advise??
hi and welcome to the forum ,
Unfortunately large size combis are expensive , what was the old boiler type size ?
Personally judsjasper go for the larger output appliance and stay clear of the 'Landlord' boilers! 24Kw are the cheapest and usually suitable for around 7-11ltr/min IMHO .. However it sounds like you're unlikely to draw more than one tap at a time. If that's so then go for something 30kW thereabouts IMO ... guarantees you a decent hot water supply in the winter! Depends on your need to be honest ... STAY AWAY FROM ANYTHING 24kW 🙂
I currently have a 13 year old Potterton Suprima 30-80 (is that right) and a Santon 150l unvented cylinder.
The Cylinder is leaking and I need a replacement so with the quote for that coming out at £850 and considering the age of my boiler, i thought it would be best to get a combi.
Add to that I don't have £850 available, my "easiest" option was to get a new combi on finance and having been stung in the past by a local plumber - i wanted to use one of the reputable companies...
noooooooooo , replace cylinder and fit new system boiler
forget about bg prices , get a independent heating engineer to do it
it will cost you a lot less then BG
cheers everyone - sounds like my concerns were valid. I'll go back and ask for a "larger" version
You'll regret your decision IMHO .. a combi, specially 24kW will have you moving home and telling lies IMHO! Replace your boiler and cylinder at the same time! Or just the cylinder for that matter as your original boiler will heat it the same as will anything else ... How old is your central heating boiler?
Here we go again - combination boilers are only suitable for flats and small houses.
Any dwelling house with more than one bathroom is not suitable. Whatever the water pressure
or litres per min quoted by the boiler manu will not serve as water pressure/volume is rarely
up to the job (esp in summer or in London).
Often some outfits spec a combi boiler because they cannot do a system/conventional system
- a combi includes all the toys - pump+timer+ so its easy to stick one box on the wall and plug it in even when its unsuitable. Fixed many unsuitable combi instals.
Also there is so much more to go wrong with combis......pressure,diverter valves etc
CHK
Reactions: 2 people
I'm in Manchester - looking at these replies - i think i need to reconsider what i'm doing!!
Too true! A move from unvented to a combi is like being use to a Porche and relying on a Skoda! Sozz to Skoda drivers, they'e relighable but don't deliver the same IMHO 🙂
You have the best system already! Just replace boiler and cylinder. Will give the best performance by far and as you already have pipework and controls in place, you would be stupid to change to a combi. Most backwards step ever
Reactions: 3 people
