american fridge freezer and 3 bar pump
View the thread, titled "american fridge freezer and 3 bar pump" which is posted in USA Plumbers Advice on UK Plumbers Forums.
R
REDSAW
customer wants a fridge freezer for ice and chilled water running from header tank on a gravity mains supply?.
can you do this?/?///:willy_nilly:
another request is to tap into the bath tap 22mm pipes and connect a 3bar pump for 2 showers instead of dedicated supply via essex flange
comments?:75:
Should make for interesting discussions when having a whiskey with ice.
On the plus side it would make checking the inhibitor concentration a lot easier.
Tee of at the top of the cylinder if the head of pressure is good enough it will work, if not how about a Surrey Flange?
Is that a pigeon feather in my ice cube?
My understanding is that even with a bylaw kit it is drinkable but not potable based on possible temperature change during storage. I should imagine the fridge mi's require a potable feed
No, its got a 100 gallon cold water storage tank for all 4 bathroom supplies not the headr tank.lol
Sorry Redsaw, don't know where I saw F&E in your OP the sad thing is I can't even blame the drink LOL
Not sure about regulations but if the tanks are covered it might be ok, you have the benefit of the freezer and chiller to do some purifying.
As your in the attic why not take a feed from the mains? if the pressure is too high you can always restrict it with a valve.
With a bylaw kit the water in the cold water storage cistern is classed as wholesome. The lagging jacket is supposed to keep the temperature down. It only becomes fluid category two in the hot water cylinder.
You can lag it as much as you like. Some lofts are like saunas in summer. My preference here would be to do the job with a mains feed or let someone else do it. But that's just me!
What's the flow and pressure requirements for the fridge. It will have that ridiculously small white pipe and wm valve adaptor and have to go through the internal/external filter. Tank fed might not be upto it.
Reply to the thread, titled "american fridge freezer and 3 bar pump" which is posted in USA Plumbers Advice on Plumbers Forums.
REDSAW,
REDSAW,
