View the thread, titled "An Boiler be left on with water tuned off?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have a Worcester Greenstar boiler and would prefer to turn off the water supply to the house during 2-week absence. Is it safe to do this?
Advice appreciated.
I believe the answer to your question is: it should be fine. I discovered some years ago that lack of water in the boiler jacket - ie you are unfortunate enough during your holiday break (when you have turned off the stopcock) to have a leak that drains the F&E cistern and the boiler - causes the boiler to shut itself off as it reacts to the sensors on the boiler casing getting too hot. Of course there is always the risk that the boiler circuitry fails to work but that could occur whether you're on holiday or just out for the day and boiler manufacturers usually don't skimp on such safety matters - bad for business!
BTW, ShaunCorbs point about dropping the target heating temperature to just 12degC is a good one. Many house insurance policies stipulate that as a minimum maintained temperature and, if your house is half-decently insulated, your boiler won't want to be coming on during your absence anyway. We always leave ours on when we are away ever since, many moons ago, we came back to a house that was 6degC and the boiler refused to start as it was too cold! I had to remove the jacket sensors, heat them with a heat gun, start the boiler and wait until the circulating water temperature got up to 10degC before I could replace the sensors and let the boiler function normally! It took 2 full days to get the house up to a decent temperature - never again!
Reply to the thread, titled "An Boiler be left on with water tuned off?" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Traveller 47,
Traveller 47,
