View the thread, titled "any idea whats wrong???" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
andrew69
my ideal he 18 boilers not working, ive no hot water or heating, and theres no lights at all on the display panel, no fuses look like theyve blown, our gas still works on the hob and i can still use my emersion for hot water...what could be the problem:confused5:
oh, thanks powerflow for your time in replying... and a happy new year to you
Maybe it has just popped out down the town for a knees up :wink:
If you can work a multi meter or test lamp you can figure this one. If not wait until tuesday it will be cheaper.
Happy new year
Get a gsr engineer. Should only charge if they fix. If not it might be a boiler that works off switched lives that may require a spark.
No the icos has a permanent live. Most likely cause is pcb but a slow running fan can take out the pcb. I looked at one recently and the fan had taken out the pcb and user control. I advised the customer to get ideal out on a fixed price repair as the cost of parts would have come out higher. I didn't charge but got a £20 tip.
causes could be, main 3 amp fuse, pcb quickblow fuse, on/off switch faulty, pcb or user display, simple tests will rule these out, my moneys on the pcb but you need a gas safe engineer to look at it.
Reply to the thread, titled "any idea whats wrong???" which is posted in UK Plumbers Forums on Electricians Forums.
