All inlet valves downstairs are scorching hot. All rads have been bled. First 3 rads on system downstairs are warm but there 4 after that are not.Got closer. Yes arrow on right is downwards. View attachment 80051
What does venting air mean?Very strange allright, presume not something daft like the pump valves not opened fully, they look like gate valves so should be ~ 3 or 4 full turns from fully shut to fully open. There arn't too many things left, the pump was probably changed out without drain or partial system drain down, possible sludge build up but unlikely except the F&E tank was full of crap and drained down into the system. (if system drained)
The possibility of a faulty UPS3 still exists but if so unlikely that air would continue to build up, are you still venting air, you say all rads have been bled?.
CP1 at 3M should not cause any problems and is required for most systems of your size, my system runs at 3.5/3.6M with the (Wilo) pump set to a PP setting of 4.6M.
John, should the gate valve directly under the pump be fully open? The middle of the three you can see in the photo I uploaded yesterday.What does venting air mean?
Opening the vent screws and getting rid of any air in the rads. (Bleeding the rads)What does venting air mean?
Not sure about the one with the red handwheel (you would have to trace it but let it be just now whatever its opening is).John, should the gate valve directly under the pump be fully open? The middle of the three you can see in the photo I uploaded yesterday.
Cheers. In work now so will try again when I get home late afternoon.Opening the vent screws and getting rid of any air in the rads. (Bleeding the rads)
The two brass valves, immediately above and below the pump MUST be fully open, get a adjustable spanner or even a pliers and try shutting first, if they are open then you should get 3 to 4 turns to shut, then immediately reopen, ie they must be ~ 3 to 4 full turns open from fully shut.
That middle pipe seems to go into the bottom of the immersion heater.Cheers. In work now so will try again when I get home late afternoon.
Yes, all rads are bled - doing it all the time. No air in them.Opening the vent screws and getting rid of any air in the rads. (Bleeding the rads)
probably the cold water supply to your HW cylinder.That middle pipe seems to go into the bottom of the immersion heater.
Thanks John. I have bled the rads but not emptied them per se - when you say 'no circulation or corc pump defective' what else could cause the 'no circulation'? The weird thing is that on Sunday after I changed to CP2 all rads were hot, same Monday but then Monday night the downstairs rads went cold. So that must be an airlock? But there is no air in rads! Given that we have had heat i would guess the pump valves are fully open.If no air in them then pointless venting, except that you are getting some heat in them by actually bleeding off a few litres of water which means no circulation or circ pump defective, CP2 at 4.5M even with all rads open (no balancing) should circulate plenty of water to get all/most quite hot, you have another problem IMO.
When you come home and if you find that the pump valves are fully open (and probably are) then may have to check the circ pump.
last one - the screw in the pump to deblock - manual says to turn screwdriver anticlockwise, but youtube vids say ant and then clockwise? Is that a possible issue?Thanks John. I have bled the rads but not emptied them per se - when you say 'no circulation or corc pump defective' what else could cause the 'no circulation'? The weird thing is that on Sunday after I changed to CP2 all rads were hot, same Monday but then Monday night the downstairs rads went cold. So that must be an airlock? But there is no air in rads! Given that we have had heat i would guess the pump valves are fully open.
Don't think so, if it needed deblocking anyway you should get a LED alarm.last one - the screw in the pump to deblock - manual says to turn screwdriver anticlockwise, but youtube vids say ant and then clockwise? Is that a possible issue?
Yes, balanced all rads up and down a few times.Turn all the rads off downstairs bar one, get that one red hot. Turn it off. Turn next one on and repeat for rest. It's just airlocking that's all by the sounds of it. If valves are red hot to radiators, then sounds like air. You've not balanced up downstairs have you?
No idea sorry as I was not here. I reckon so as it was a British Gas engineer as we have the home care.Was the pump renewed without any drain down?
Unbalance the downstairs ones, so they're open fully. Leave upstairs balanced.Yes, balanced all rads up and down a few times.
Had a plumber come round. He has checked the pump, the valves, drained the system, rebled the system, checked the feeder tank in loft and it is still the same. He is convinced there is a blockage in the 'return' feed pipe (I am not going to pretend I know what that is) and we need to do a powerflush.
