any tips for removing a stubborn Immersion Heater
View the thread, titled "any tips for removing a stubborn Immersion Heater" which is posted in UK Plumbers Forums on UK Plumbers Forums.
scottplumber
I've replaced a few immersion heaters in my time but always have trouble getting them out and putting them in without a few trouble along the way. I'm in the middle of doing one now and i've left water in the tank so i can get a turn on it but its not having none of it any tips much appreciated really dont want to damage the cylinder.
thanks
Scott
The careful application of heat which if the cylinder is foam lagged will need to be made to the inner surfaces of the heater to avoid burning the insulation will normally get it moving.
Make sure sufficient water has been drained from the cylinder to allow the blow lamp to heat it properly. Also make sure that you,ve got enough leverage on the tool you are using but be very careful not to put too much pressure on as the boss will distort.
Jon
which spanner you got?the one to have is the cranked cast steel one a sharp tap with the club hammer usually gets it moving if not then heat and repeat
If you have tried everything above try this as a last resort!
Drill a hole in the centre of the immersion big enough to slide a hacksaw blade in, then cut up to the thread being careful not to cut into thread. Then cut another line 90º from the first cut so your cutting a 1/4 of the immersion out. I then normally cut the face of the immersion where i have just made the two cuts which then if you get a screwdriver you can then snap the 1/4 out.
Then if it still doesn't budge just cut the rest of that half out and the other side will pop out with a little tap. Its a long winded way of getting it out but if it saves damanging/replacing the cylinder then its all good.
Hope I explained this good enough.
The trouble with the box spanner when it's really tight is the torquing effort is above the hexagonal nut of the immersion and it slips off. I have successfully used a chain wrench as this cannot slip and all the effort is at the right point.
Now thats what I call dedication
ive used several immersion spanners and none of them seem to do the job very well. Ive got a huge pair of grips that do the job perfectly
I've always found the cast box spanner and lump hammer trick works every time. As long as the cylinder is full it doesn't distort. I certainly wouldn't muck about cutting one out, time you do that it'll cost the custard more in labour than a new cylinder. Plus you get a good bit of scrap.
glad we agree on the cast spanner ive never had to cut one out yet and ive ony ever split one cylinder
all this talk of cylinders has jogged my memory to the silliest mistake i made with one
called to a job with no hot water i grabbed the multimeter stuck the black lead on the cylinder and the red on the terminal to test for juice unfortunatly the last thing id done with the meter was an amp reading the black lead arced straight throught the top of the cylinder and the stream of water hit me dead center on the chest its amazing how fast your brain tells you that water and electrics loose in a small airing cupboard with you isnt a good idea
I've always had good results with my cast spanner and a hammer which concentrates the torque at the hexagonal ring. My steel box spanner always seems to apply the pressure too far up causing a twisting action.
i've got both box and cranked flat spanner and must say i get most use out of the box one really.
Hammer and screwdriver will move most stubborn ones. Cut the lagging back and heat if it still won't move. Shock is the thing you want to do, not brute force. A set of 24" stilsons would most likely mean a new cylinder.
Only drain a gallon or so from the cylinder. Just enough to get below the level.
WD40 won't do any good. The threads are sealed with tape or probably boss white if it is not moving so it will penetrate nothing.
tamz
what exactly do you mean by hammer & screwdriver?
what methid needs to be applied?
Think Tamz means a large screwdriver or cold chisel hit with a hammer with force to induce a "shock" to break the sealing compound, once it`s moving then the spanner or large grips will unscrew it. Just increase the amount of force used slowly and keep an eye on the tank for any ripples in the metal.
cut the outer raised edge of the element with a hack saw or multi tool ( 1st cut straight down 2nd 5mm to the left of 1st cut down at an angle to meet the 1st). then get a roto stop drill with chisel in the groove, this will break the seal with ease. undo with box spanner, clean off and fit new. you do not need to put anything on this to seal it only the fibre washer it came with!!!!!! that's why you cant get the old one off.
I've not changed that many as of yet, so I'm still waiting for the day I get a stubborn little sod.. So far I just start draining, while it's draining I put my box spanner on it and try and get it moving. So far so good. I did have to use a bit of heat on one I changed. Not a lot mind.. But got it out in the end. I need to get a longer tommy bar for my box spanner to make it easier 😉
Dont know where i saw this but it worked a treat on one the other day. heat the immersion with a blow torch get it nice and hot then throw a really wet rag on top cracked the joint a treat, then a descent box spanner quickly to remove
then put all the towels on fire in the cupboard in the bath and run away.........................
Reply to the thread, titled "any tips for removing a stubborn Immersion Heater" which is posted in UK Plumbers Forums on Plumbers Forums.
scottplumber,
Old Account,
