Anyone plumb a DIY hot tub?
View the thread, titled "Anyone plumb a DIY hot tub?" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
I bought a used acrylic hot tub shell that I plan to sink into the ground in the backyard. The plan is to heat it with a tube/shell exchanger off my thermal store, with a main pump for the jets, and a circulating pump for the filter and heat.
  • anyone know a good place to buy jets, and other hot tub parts?
  • if the system has two pumps, I assume they need to be in parallel. Does one need check valves to prevent back flow through the reciculating pump when the main one is on?
  • any ideas for the best way to insulate it from the ground?
I plan on putting the pumps & controls in my workshop which is about 4m away. I suppose this is too far away for an air switch, what is the best way to get around this?
Reply to the thread, titled "Anyone plumb a DIY hot tub?" which is posted in DIY Plumbing Advice on Plumbers Forums.
siricosm,
