Aqaulisa shower cartridge
View the thread, titled "Aqaulisa shower cartridge" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Plum Bob 66
Hi Guys
I need to change the cartridge on my customers aqaulisa aqauvalve shower. For those of you that Know is this a simple operation and is there anything I should look out for for.
PS thanks for the electric shower advice, worked a treat !
Plum Bob 🙂
If you mean the 609 or 700, then yes its easy enough. Isolate the supplies, remove the on/off knob (push in one side of the "aqualisa" badge and it should pop out then remove the screw and prise off the knob with a thin blade), undo the 4 screws holding the temperature ring in place (note the positions of the various plastic rings etc) then undo the screws holding the cartridge in place and pull it out releasing a gush of water as it comes off. the new one should come with any new o rings etc and particular instructions for refitting. 15 minute job.
If it's the one I think it is, getting the old o-ring out of the housing is a right ****. THe instructions say use a crochet hook. How many plumbers have a crochet hook?
I have an old dental pick which is perfect for the job. Have a word and see if you can scrounge an old one from your dentist.
Reply to the thread, titled "Aqaulisa shower cartridge" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Plum Bob 66,
NickH,
