View the thread, titled "Aqualisa shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Steve88
I am a bit stumped... I am currently on a maintenance job for a leaky shower and am unsure what to do. The leak is coming from the thermostatic cartridge and am unsure what to do next. I think I may need to completely change the cartridge but was wondering if there was anything I may have missed.
also the problem, I believe has caused a leaky shower head which will just need a washer replacing.
thanks in advance for your help.
steve
Hello Steve.
If the leak is coming from the Aqualisa cartridge, then you need a new cartridge for sure.
Be careful you get the exact type, as there are different but similar looking cartridges for these showers.
Beware there is an O ring supplied with some that fits inside the body & you will need an O ring picker perhaps to remove old one. Use a screwdriver centred in the body, to slide the new O ring into place & be careful not to drop it into the bottom outlet!
If the shower head is also dripping, then replacing the cartridge & O ring will also cure that.
Check online with Showerdoc for your exact model, if in doubt.
Reply to the thread, titled "Aqualisa shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
