Neil T
Subscribed
Dec 23, 2011
207
31
28
Sale, Manchester
General Plumber
Hi all,
Anyone know of any companys that buy original American Radiator Company cast iron roads around Manchester or in north west?
Got one off a customer that will need some tlc 60h x 43l x 14w (cm) , 4 columns and 8 sections. Got be worth something to someone rather than scrap it. Btw, what would I get for it scrap? Probably weighs in region of 35-40kg.
Cheers
Reactions: Neil T
Cheers for that Shaun, sent an email with a couple of pics to castrated.. they're actually not too far from me 🙂
Did that customer ever get in touch about water heaters?
Reactions: ShaunCorbs
yes and sorted a price, he said your doing all the first fix and we just need to connect to your tails through the floor that your going to leave
tmv3 on the toilets basins i belive your having and think your supplying the 50mm push fit waste from the stack for the t and p
secondary returns on the bar area and toilets
if we get the job will give you either a pm or phone call
think he will have a shock with the price tho tbh 3ph 500l single cylinder recover time of under 60mins etc
Lol just seen that predictive text put castrated instead of castrad 🙂
Yeah, just waiting to go in and chat with joiners about the pipe runs and for start date.
What's the 't and p' in "push fit waste from the stack for the t and p" Btw?
good luck 🙂 and temperate and pressure valve from the unvented cylinder
No worries will have that in place. Need to find out off him where exactly he wants it sited too as I believe there's been a change of plan.
Yea, just let us know what happens your side and we might meet up on the job 🙂
just to give you a heads up he said when i went there same wall as panel either next to the panel (tbh dont like this but easy for the sparks) or in the corner (right hand side)
Reactions: Neil T
Nice one, hoping to get there this week and gets things moving
ok 32mm main incoming water main could you find out the pressure and flow rates for me, as did ask client but hasnt got back to me yet
min of 35mm main cold pipework also if you would be so kind
