Ariston combi boiler - not firing up in DHW mode!
View the thread, titled "Ariston combi boiler - not firing up in DHW mode!" which is posted in Boiler Advice Forum on UK Plumbers Forums.
M
Marty32
Hi chaps
Got an Ariston combi boiler (no idea of model but its a big beast, wall mounted) been fine up until yesterday where it doesn't always fire up when opening the hot tap. I have pressed the reset button which only seems to work on occasions.
Is it something to do with the diverter valve or diaphragm and if so is this a job for GSR engineer?
Cheers
Mart
Depends on the Ariston that you have got. Best port of call maybe to find a local gsr from the forums. Atleast you know you not getting some mug with a ticket and no clue that may charge u a fortune
Simple things to check in the mean time. stopcock open and good flow thru hot water tap. Other than that call someone gsr
Sent from my iPhone using Tapatalk
Is it a euro combi?
Flip down cover on the bottem with a grey panel. And red light in the middle that is the reset button?
Sorry if I'm being thick is that another name for a diverter valve or is it just switch is blown a fuse or something?
:dizzy2:
Marty32!!!!!!
You had a Biasi screeching the other day??? Have you moved house?
Or do you wear a stetson ???:cowboy:
Marty32 .... don't mess with combi's other than your own man! Picking our experience for your own gain may at the least get you into trouble and at worst KILL someone!
well spotted steve,i was dubious when he said the ariston was a big beast its a microgenus
It'll be interesting to see if he come's back here or just changes his alias and uses us all again! I hope he knows how potentially dangerous it is to be over confident when messing with gas?
Marty32!!!!!!You had a Biasi screeching the other day??? Have you moved house?Or do you wear a stetson ???:cowboy:
Ha ha ha yeah jingle my spurs Diamond! Mine is that **** Biasi but my wife's mum and dad have the Ariston so thought I'd ask on their behalf 😀All the best The Sun Dance Kid
Mart there's nothing wrong with having confidence in working with gas, its the competence you'll be lacking which can be very dangerous! I noticed that you started off with some plumbing experience, nowt wrong with gaining more. I hope you appreciate the reason for limiting info to those who show competence!
Be safe Sun Dance :rockon2:
Reply to the thread, titled "Ariston combi boiler - not firing up in DHW mode!" which is posted in Boiler Advice Forum on Plumbers Forums.
Marty32,
diamondgas,
