ariston microgenius type c boiler
View the thread, titled "ariston microgenius type c boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
lloydy
hiya,
iv got an ariston micro genius type c boiler which keeps locking out. this problem happened at the end of last winter, i called someone out who bled the radiators and has worked since!! But since the cold snap lately it has started happening again. If water is called for it is usually fine. but when the heating is turned on it locks out. i reset it then can work for an hour or so then locks out. its 11yr old so wondering if its worth spending probably going to be £100 -£200 on repairing it or do i buy another.
Is there anything i can try before some1 comes out.
If new boiler is required any recommendations??
Regards.
hiya,
Regards.
I would get one of the plumbers on here to come and have a look at your boiler before deciding to go for a new one
Goto need a plumber and put a request there and see how you go from there.
I assume you have bleed the Rads and the pressure is above 1bar
Jay
Reply to the thread, titled "ariston microgenius type c boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
lloydy,
jays,
