ariston programmer
View the thread, titled "ariston programmer" which is posted in UK Plumbers Forums on UK Plumbers Forums.
B
brian_the_gas
Hi every one
Got myself a bit of a problem with an Ariston time clock, after some considerable messing about I have come to the conclusion that the timer is shot ( after setting on off times, the boiler wont respond) can I fit an external programmer or must I use an original part. The boiler is about 15yrs old and I cant seem to find the same clock any where
Thanx in advance
Brian😕
I would imagine that you could bypass the programmer and fit another on the room stat connections. You really need to check the manufacturers instructions before attempting anything though.
Mike
Reply to the thread, titled "ariston programmer" which is posted in UK Plumbers Forums on Plumbers Forums.
brian_the_gas,
brian_the_gas,
